Hi All
Where do I store Images on HA, and how do I link to them
Do I have to put a folder in the share folder or config folder
plus do I need to add any code for HA to find this folder
Thanks for you help
Paul
Hi All
Thanks for you help
Paul
If you want them to be accessible outside your local network put them in
\config\www\
You can access images locally directly from this folder.
If you need to access these files from outside your network they can be found at:
https://yourdomain.duckdns.org/local/
Assuming you use duckdns.
