Running HASSIO as a Hyper-V VM with Supervisor. HA is reporting that the disk is 90% full but when I log in via the terminal and run df it is only reporting 1.8 GB in use. I can’t figure out how to track down the usage!
run
ha su repair
to clean up your disk.
that didnt free up any space
How big is your disk ?
6 GB allocated. But when i run du it only shows 1.8 GB in use
docker image prune -a
? Could remove a bit more than ha su repair
That didnt free up any space
I figured out I was checking disk usage of the Home Assistant container and not BusyBox OS.
I needed to run login on the console before I could track down the usage. Found about 2 GB was in use by AdGuard logging.
