I can’t seem to figure out what items specifically change Home Assistant’s terminal. Does anyone know what changes the background and foreground colors of the terminal in the theme file?
I’m guessing that the terminal add-on doesn’t follow lovelace themes within the terminal window. Instead, I’d treat it as you would changing the color/theme in any Linux terminal, probably starting by searching how to change colors for the version of shell that’s being run (in this case, I think it’s zsh).
Thank you for your reply. I’m curious, if the addon terminal doesn’t follow Lovelace themes, why do the colors change when switching themes?
Oh - maybe it only adhere’s partially. You could try opening a github issue with the add-on.
Thanks, that’s what I’ll do.
