I started to use Utility Meter - I set up some meters using the Create Helper UI. I find I have set one up wrong (it complains about non-numeric input). How do I edit it? I have searched all the files in the config folder, but can’t find any reference to the “sensor.import_today” utility meter I set up.
Also, where do I find documentation on the configuration files? I have added a load of stuff to my configuration.yaml file, but I think it would be better in an include file. But I don;t know what the proper syntax is.
My configuration.yaml is
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
modbus:
- name: Nibe
type: tcp
host: 192.168.1.251
port: 502
sensors:
- name: nibe_smos40_bt1
unit_of_measurement: °C
data_type: int16
device_class: temperature
address: 1
input_type: input
scale: 0.1
precision: 1
state_class: measurement
slave: 1
(there is more).
How do I put the modbus bit in an include file - what syntax do I use?
