I’seen videos showing that you can access the groups.yaml by using a File editor.
So i went and installed the File editor Click on the folder icon and there is no “Groups.yaml” there
How can i add that or where is it ?
Here is an image
Here is an image
you can just create one in the root directory. Same directory that holds the configuration.yaml.
Just to be sure…
Does it means that i can use the configuration.yaml and add the groups there or is it that once i create a groups.yaml, i need to go to the configuration.yaml and add that line “group: !include goups.yaml” to make the groups works?
Yes, you can add groups directly in configuration.yaml. Creating a separate groups.yaml can make your main configuration cleaner.
@123 Because i’m not sure to understand your answer correctly is why i asked for a small clarification
