Where is the config file stored for supervised installations?
I did a supervised installation on my RPi.
I screwed up the configuration.yaml and now HA won’t start up. How do I undo my changes/edit the config file?
On my installation :
/usr/share/hassio/homeassistant
I managed to remove those lines still I can’t access HA on the web…
● hassio-apparmor.service - Hass.io AppArmor
   Loaded: loaded (/etc/systemd/system/hassio-apparmor.service; enabled; vendor preset: enabled)
   Active: active (exited) since Sun 2020-03-29 22:58:17 IST; 4min 14s ago
  Process: 1753 ExecStart=/usr/sbin/hassio-apparmor (code=exited, status=0/SUCCESS)
 Main PID: 1753 (code=exited, status=0/SUCCESS)
Mar 29 22:58:16 pi4 systemd[1]: Stopped Hass.io AppArmor.
Mar 29 22:58:16 pi4 systemd[1]: Stopping Hass.io AppArmor...
Mar 29 22:58:16 pi4 systemd[1]: Starting Hass.io AppArmor...
Mar 29 22:58:17 pi4 hassio-apparmor[1753]: Warning: unable to find a suitable fs in /proc/mounts, is it mounted?
Mar 29 22:58:17 pi4 hassio-apparmor[1753]: Use --subdomainfs to override.
Mar 29 22:58:17 pi4 hassio-apparmor[1753]: [Error]: Can't load profile /usr/share/hassio/apparmor/hassio-supervisor
Mar 29 22:58:17 pi4 systemd[1]: Started Hass.io AppArmor.
● hassio-supervisor.service - Hass.io supervisor
   Loaded: loaded (/etc/systemd/system/hassio-supervisor.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2020-03-29 22:58:10 IST; 4min 21s ago
  Process: 1068 ExecStartPre=/usr/bin/docker stop hassio_supervisor (code=exited, status=0/SUCCESS)
 Main PID: 1086 (hassio-supervis)
    Tasks: 11 (limit: 4915)
   Memory: 66.8M
   CGroup: /system.slice/hassio-supervisor.service
           ├─1086 /bin/sh /usr/sbin/hassio-supervisor
           └─1121 docker start --attach hassio_supervisor
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.discovery] Load 0 messages
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.ingress] Load 4 ingress session
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 1
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [__main__] Run Supervisor
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.addons] Phase 'system' start 0 add-ons
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (MainThread) [supervisor.addons] Phase 'services' start 0 add-ons
Mar 29 22:58:20 pi4 hassio-supervisor[1086]: 20-03-29 17:28:20 INFO (SyncWorker_13) [supervisor.docker.interface] Start homeassistant/raspberrypi4-homeassistant
