I’m using hassio (HassOS 2.12, Home Assistant 0.102.2), and the add-on “NGINX Home Assistant SSL Proxy” 2.5.
The ‘Log’ section at the bottom of the add-on detail page shows only " INFO: Running nginx…". That is also I see in response to ‘hassio add-on log core_nginx_proxy’.
I’d really like to see the typical access log from nginx, to see the responses that the server is sending to a client.
Maybe there isn’t an access log by default? If I have to use the add-on’s customize.activate and customize.default settings, may I have help with the format?
