Where is the wink config data stored?
I’m getting the “client is not authorized” error and I’m pretty sure I know the problem. When I check the logs I had accidentally put a “.” at the end of my call back url. I changed it on the wink developer site, but hassio still shows the period at the end of the url. If I could go in and just remove the period I think it will fix it. I have the configurator add on installed which lets me explore the root system. It’s not in the .wink.conf file because that just shows the client id and client secret.
Thanks for the help!
The client ID and client secret are stored in the hidden file .wink.conf which is located in your config folder. However, the callback is obtained from their site so if its still wring you should clear cache or try a private mode/incognito tab to avoid using a cached URL
