hi,
i’ve connected home automation to zigbee2mqtt by the automatic discovery way. A lot of devices as been created but i can’t find the associated yaml configuration file in the files editor. Where can i find this file ?
thanks
hi,
thanks
It does not exist. Discovered devices are stored as json in the .storage registry. This is not meant to be user editable.
What do you want to do?
i’ve a few problems with the discovery. Some switch don’t want to work and i’d like to see the definition of them created by the discovery.
And if I a create a same switch by myself i’ve no problem.
for exemple the auto discovery switch.lumiere_nuit_bas doesn’t work and the same switch design by myself switch.cmde_lumierebas1 work.
This json file is in binary ?
no it’s in regular text but in json format instead of yaml
thank you and where i can find the storage registry ?
it’s in your config directory in the possibly hidden .storage folder (note the “.”)
ok i’ve found the definition in /usr/share/hassio/homeassistant/.storage file= core.entity_registry
"area_id": null,
"capabilities": null,
"config_entry_id": "1baa6d32c627fcc8380eab7b5b7fc81b",
"device_class": null,
"device_id": "b71ff758470a4e656a8cf6090cfc2fc3",
"disabled_by": null,
"entity_category": null,
"entity_id": "switch.lumiere_nuit_bas",
"icon": null,
"id": "2ae688992110e68109f35f55bf7fcafd",
"name": null,
"options": {},
"original_device_class": null,
"original_icon": null,
"original_name": "lumiere nuit bas",
"platform": "mqtt",
"supported_features": 0,
"unique_id": "0x000d6ffffeaacf99_switch_zigbee2mqtt",
"unit_of_measurement": null
difficult for me to see if all is right.
i think my problem come from my home assistant integration in zigbee2mqtt software.
i’ve tried to change a few thinks and for the moment all work fine now.
when i click for switch off the light 2 messages are send on mqtt
zigbee2mqtt/lumiere nuit bas
"linkquality": 255,
"power_on_behavior": null,
"state": "OFF",
"update": {
"state": "available"
"update_available": true
ziggbee2mqtt/bridge/logging :
"level": "info",
"message": "MQTT publish: topic 'zigbee2mqtt/lumiere nuit bas', payload '{\"linkquality\":255,\"power_on_behavior\":null,\"state\":\"OFF\",\"update\":{\"state\":\"available\"},\"update_available\":true}'"
before the changes i'd only the first message
