Hi Everyone,
I use HA Core in a python venv.
I was using python3.10 and I am updating my python to the 3.11.
After the python and HA updates to the latest version, I am having issues when I try to start it (sudo systemctl start [email protected]).
As HA is not up yet, I can’t see anything in homeassistant.log
Any idea about where I can see what is the reason for the failure startup? Some other Log
I have Fedora 35.
This is what I get when I ask for a Status (systemctl status [email protected])
[email protected] - Home Assistant
Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: disabled)
Active: failed (Result: core-dump) since Fri 2023-06-16 10:20:55 EDT; 32s ago
Process: 19628 ExecStart=/opt/homeassistant311/bin/hass -c /home/homeassistant/.homeassistant (code=dumped, signal=ILL)
Main PID: 19628 (code=dumped, signal=ILL)
CPU: 4.057s
Jun 16 10:20:48 hanew systemd[1]: Started Home Assistant.
Jun 16 10:20:55 hanew systemd[1]: [email protected]: Main process exited, code=dumped, status=4/ILL
Jun 16 10:20:55 hanew systemd[1]: [email protected]: Failed with result 'core-dump'.
Jun 16 10:20:55 hanew systemd[1]: [email protected]: Consumed 4.057s CPU time.
Thank you
