Thanks for responding so quickly.
Here ist the report. The device is ready, the Interview is complete.
I cannot see anything in it about temperature, but I was using the sensor until yesterday using the same z-wave stick, , so I know it’s there.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.10.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"timezone": "UTC",
"os_name": "Linux",
"os_version": "5.15.67",
"supervisor": "2022.10.0",
"host_os": "Home Assistant OS 9.0",
"docker_version": "20.10.17",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"ui_lovelace_minimalist": {
"version": "v1.1.4",
"requirements": [
"aiofiles==0.8.0",
"aiogithubapi>=22.2.4"
"alarmo": {
"version": "v1.9.5",
"requirements": []
"hacs": {
"version": "1.27.2",
"requirements": [
"browser_mod": {
"version": "2.1.2",
"requirements": []
"reolink_dev": {
"version": "0.57",
"requirements": [
"reolink==0.0.62"
"uptime_kuma": {
"version": "1.2.1",
"requirements": [
"pyuptimekuma==0.0.6"
"picotts_remote": {
"version": "1.0.1",
"requirements": []
"dwains_dashboard": {
"version": "3.3.0",
"requirements": []
"skyq": {
"version": "v2.9.10",
"requirements": [
"pyskyqremote==0.3.16"
"watchman": {
"version": "0.5.1",
"requirements": [
"prettytable==3.0.0"
"integration_manifest": {
"domain": "zwave_js",
"name": "Z-Wave",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zwave_js",
"requirements": [
"pyserial==3.5",
"zwave-js-server-python==0.43.0"
"codeowners": [
"@home-assistant/z-wave"
"dependencies": [
"usb",
"http",
"websocket_api"
"iot_class": "local_push",
"usb": [
"vid": "0658",
"pid": "0200",
"known_devices": [
"Aeotec Z-Stick Gen5+",
"Z-WaveMe UZB"
"vid": "10C4",
"pid": "8A2A",
"description": "*z-wave*",
"known_devices": [
"Nortek HUSBZB-1"
"zeroconf": [
"_zwave-js-server._tcp.local."
"loggers": [
"zwave_js_server"
"is_built_in": true
"data": {
"versionInfo": {
"driverVersion": "10.3.0",
"serverVersion": "1.24.0",
"minSchemaVersion": 0,
"maxSchemaVersion": 24
"entities": [
"domain": "sensor",
"entity_id": "sensor.solar_powered_outdoor_siren_battery_level",
"original_name": "Battery level",
"original_device_class": "battery",
"disabled": false,
"disabled_by": null,
"hidden_by": null,
"original_icon": null,
"entity_category": "diagnostic",
"supported_features": 0,
"unit_of_measurement": "%",
"value_id": "179-128-0-level",
"primary_value": {
"command_class": 128,
"command_class_name": "Battery",
"endpoint": 0,
"property": "level",
"property_name": "level",
"property_key": null,
"property_key_name": null
"domain": "switch",
"entity_id": "switch.solar_powered_outdoor_siren",
"original_name": "",
"original_device_class": null,
"disabled": false,
"hidden_by": null,
"entity_category": null,
"unit_of_measurement": null,
"value_id": "179-37-0-currentValue",
"primary_value": {
"command_class": 37,
"command_class_name": "Binary Switch",
"endpoint": 0,
"property": "currentValue",
"property_name": "currentValue",
"domain": "binary_sensor",
"entity_id": "binary_sensor.solar_powered_outdoor_siren_low_battery_level",
"original_name": "Low battery level",
"disabled": false,
"hidden_by": null,
"value_id": "179-128-0-isLow",
"primary_value": {
"endpoint": 0,
"property": "isLow",
"property_name": "isLow",
"state": {
"nodeId": 179,
"index": 0,
"installerIcon": 3329,
"userIcon": 3840,
"status": 4,
"ready": true,
"isListening": false,
"isRouting": true,
"isSecure": true,
"manufacturerId": 340,
"productId": 2,
"productType": 4,
"firmwareVersion": "1.4",
"zwavePlusVersion": 1,
"name": "Sirene",
"location": "**REDACTED**",
"deviceConfig": {
"filename": "/data/db/devices/0x0154/005107_0.0-1.4.json",
"isEmbedded": true,
"manufacturer": "Popp & Co",
"label": "005107",
"description": "Solar Powered Outdoor Siren",
"devices": [
"productType": 4,
"productId": 2
"firmwareVersion": {
"min": "0.0",
"max": "1.4"
"paramInformation": {
"_map": {}
"label": "005107",
"interviewAttempts": 1,
"endpoints": [
"nodeId": 179,
"index": 0,
"userIcon": 3840,
"deviceClass": {
"basic": {
"key": 4,
"label": "Routing Slave"
"generic": {
"key": 16,
"label": "Binary Switch"
"specific": {
"key": 5,
"label": "Siren"
"mandatorySupportedCCs": [
32,
37,
133,
89,
128,
114,
115,
134,
94
"mandatoryControlledCCs": []
"commandClasses": [
"id": 37,
"name": "Binary Switch",
"version": 1,
"isSecure": false
"id": 133,
"name": "Association",
"version": 2,
"isSecure": false
"id": 89,
"name": "Association Group Information",
"version": 1,
"isSecure": false
"id": 128,
"name": "Battery",
"version": 1,
"isSecure": false
"id": 114,
"name": "Manufacturer Specific",
"version": 2,
"isSecure": false
"id": 115,
"name": "Powerlevel",
"version": 1,
"isSecure": false
"id": 134,
"name": "Version",
"version": 2,
"isSecure": false
"id": 94,
"name": "Z-Wave Plus Info",
"version": 2,
"isSecure": false
"id": 152,
"name": "Security",
"version": 1,
"isSecure": true
"id": 122,
"name": "Firmware Update Meta Data",
"version": 3,
"isSecure": false
"id": 90,
"name": "Device Reset Locally",
"version": 1,
"isSecure": false
"values": [
"endpoint": 0,
"commandClass": 37,
"commandClassName": "Binary Switch",
"propertyName": "currentValue",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Current value"
"endpoint": 0,
"commandClass": 37,
"property": "targetValue",
"propertyName": "targetValue",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": true,
"label": "Target value",
"valueChangeOptions": [
"transitionDuration"
"endpoint": 0,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"property": "manufacturerId",
"propertyName": "manufacturerId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"min": 0,
"max": 65535
"value": 340
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"min": 0,
"max": 65535
"value": 4
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"min": 0,
"max": 65535
"value": 2
"endpoint": 0,
"commandClass": 128,
"commandClassName": "Battery",
"propertyName": "level",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Battery level",
"min": 0,
"max": 100,
"unit": "%"
"value": 65
"endpoint": 0,
"propertyName": "isLow",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Low battery level"
"value": false
"endpoint": 0,
"commandClass": 134,
"commandClassName": "Version",
"property": "libraryType",
"propertyName": "libraryType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"states": {
"0": "Unknown",
"1": "Static Controller",
"2": "Controller",
"3": "Enhanced Slave",
"4": "Slave",
"5": "Installer",
"6": "Routing Slave",
"7": "Bridge Controller",
"8": "Device under Test",
"9": "N/A",
"10": "AV Remote",
"11": "AV Device"
"value": 3
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"ccVersion": 2,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version"
"value": "4.5"
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"ccVersion": 2,
"metadata": {
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions"
"value": [
"1.4"
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version"
"value": 1
"isFrequentListening": "1000ms",
"maxDataRate": 100000,
"supportedDataRates": [
40000,
100000
"protocolVersion": 3,
"supportsBeaming": true,
"supportsSecurity": false,
"nodeType": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 7,
"deviceClass": {
"basic": {
"key": 4,
"generic": {
"key": 16,
"specific": {
"key": 5,
"label": "Siren"
32,
37,
133,
89,
128,
114,
115,
134,
94
"interviewStage": "Complete",
"deviceDatabaseUrl": "https://devices.zwave-js.io/?jumpTo=0x0154:0x0004:0x0002:1.4",
"statistics": {
"commandsTX": 122,
"commandsRX": 110,
"commandsDroppedRX": 75,
"commandsDroppedTX": 0,
"timeoutResponse": 10,
"rtt": 657.6
"highestSecurityClass": 7,
"isControllerNode": false,
"keepAwake": false
