Hello.
I had to change the API key in the SOlarEdge dashboard, that however broke the configuration in my HA (expected). But now I struggle to find where to replace the API key in HA UI.
Any help would be appreciated, thank you.
Hello.
You may have to delete the SolarEdge Integration and add it again.
An alternative maybe to instead click on the “ADD DEVICE” and go from there. I think this creates a new instance of the SolarEdge Integration and will probably create another set of entities. You’ll then have to delete the old instance anyway so not sure this alternative helps all that much
Thank you. I tried removing and adding it again and it works. Removing devices gave me some anxiety, I thought I would lose the data. ![]()
A “reconfig” option would be helpful.
Thank you again ![]()
