I am an absolute beginner. Just installed Home Assistant in Docker. I follow the docs and they advised to create the compose.yml file.
But where on my rpi4 do I have to store it in which folder??
I guess you missed the hint from the forum software not to reply to a solved topic
Create it wherever you want. I’d suggest something like this, so that you can back up one folder and get all your configurations:
/docker - holds the compose file (and related stuff)
/docker/homeassistant - your HA config folder
/docker/mosquitto - your Mosquitto config folder
And carry on creating folders under /docker
for the things you’re installing. Then you can just back up /docker
and get it all.
I really do not have a /docker folder onmy root of rpi4. During installation of Docker it has been created? I like to use compose, but I am totally confused how to do it. Docs create compose.yml file and not telling where to store it!
No. You create it.
Create it
Or create it somewhere else
Where you store it is entirely up to you
The only things that matter are:
- You remember where it is (hence my suggestion you create
/docker
and store it there) - You back it up
