Where to get a Home Assistant Yellow?
I’ve been researching which Home Assistant to buy, and decided on the Yellow. I like the fact that it has built-in Zigbee/Matter and is expandable. I understand that there was a version ready to go out of the box like the HA Green, but it has been discontinued. So, I thought I would get a kit but I cannot find one anywhere! Can anyone recommend where I might get an HA Yellow kit?
-Thanks
https://www.home-assistant.io/yellow
Just get a mini PC and add on from there.
That takes you here, and they’re all out of stock. Bummer!
Jeff’s advice above really is a better option.
N100 mini pc and a PoE zigbee dongle (if you have a PoE switch).
What about the Home Assistant Green? I was considering that since the Yellow is not currently available.
I’m sure it’s fine (I’ve never tried it). You will need the zigbee dongle as it is not built in.
