Where to get Aqara Hub V1
I want to extend my HA Installation with cheap wireless Temp/Hum Sensors.
As I read on the Integrations Page only V1 of the Aqara Hub can be easily integrated in Home Assistant.
Where in EU (or with shipping to EU) do I get the V1 of the Hub?
Br,
Johannes
I don’t think it is available anymore. However, the Aqara Temp.Hum sensors work fine with Zigbee2mqtt.
another option is to get a Conbee 2 and use it with ZHA. Allows use of Xiaomi sensors
looks interesting.
I have my HA running on Docker, but the Server is located in the basement.
My temperature Sensors should be used on the third floor (groundfloor = first floor). So I guess I will not be able to get the singal through 2 concrete floor and 1 wooden floor.
But I would have a running RPi with Weewx on the third floor where I could install the USB Adapter for Zigbee.
If I then would use zigbee2mqtt then I could send the sensors via my MQTT Server in the basement to HomeAssistant.
I went now with the zigbee2mqtt
Unfortunatley I have overseen that I need to flash the stick, but luckily with some kind of flexibility I was able to flash it by just using Cables and RPi :slight_smile:
The first Temperature Sensor is already online.
