Hi all, as you may know the configuration for switches is changing and is moving under the command_line
dict. However, I have yet to find a way to format the wake_on_lan stuff according to the new layout. The wake_on_lan documentation still indicates that you should put something like this is your configuration.yaml
switch:
- platform: wake_on_lan
mac: MAC_ADDRESS
This of course has been working for a very long time but triggers a “problem” in HA as this will be removed in 2023.8
I tried doing this:
command_line:
- switch:
mac: "60:a4:4c:cd:31:60"
turn_off:
service: shell_command.turn_off_rosanna_desktop
But that results in the following error
Invalid config for [command_line]: [platform] is an invalid
I tried moving the config under
wake_on_lan:
In the configuration.yaml which removes the error but also the switches (obviously) no longer function.
I’m not exactly sure what to do to fix this
In the mean time, I have migrated what I can under the command_line
section but have left a switch:
section just for my wake_on_lan
stuff.
What am I missing?
