Presswerk65
(Ueli Schwander)
November 5, 2021, 6:39am
1
Hi community! Yesterday I have updated to 2021.11.0
In 2021.10.7 I had several instances of the Octoprint-Plugin (configured in YAML) - in the new version, you can only configure via GUI and just one single instance, so support for multiple printers is broken.
Do you know where I have to put my request so the developers can do some improvements?
Greets
tom_l
November 5, 2021, 7:01am
2
They are not called “plugins” they are “integrations”.
To begin with read the release notes and forum topic. Pretty sure I saw it discussed there .
Otherwise you check here: https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A"integration%3A+octoprint"
And see someone has already reported this issue, and there is a possible solution:
opened 05:40AM - 04 Nov 21 UTC
integration: octoprint
### The problem
Prior to upgrading from 2021.10.7 I had two OctoPrint instances… connected via YAML. Both were on when I upgraded to 2021.11.0.
Only one imported correctly, the other reports "Aborted: Device is already configured" when I attempt to add it.
### What version of Home Assistant Core has the issue?
2021.11.0
### What was the last working version of Home Assistant Core?
2021.10.7
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
OctoPrint
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/octoprint/
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
