Where's configuration.yaml in Windows 7?
I just installed HASS on a Windows 7 machine, but I can’t find the configuration.yaml file. Any ideas?
Thanks!
it should be in something like …
> C:\Users\MyPc\AppData\Roaming\.homeassistant
AppData is hidden so you will have to have the correct setting in Explorer
and obviously MyPC would be your own user name
Great! Thank you :slight_smile:
thanks have been trying to open this with cmd with no luck yes i am a newbie and on windows …why do they make things so hard to find out …if they had just put this in the info would have saved so much time cheers
