Did you already receive it?
Hi.
Any news about this matter?
Hello.
This weekend I have been doing some research on this issue and I have a bit more clarity , but still have some questions.
Are an M2 A+E Key device and an M2 E Key slot compatible?
Would the M2 E Key slot in my Nuc, which is factory-used for a wifi/bluetooth card, recognize a Google Coral TPU?
If the A+E key and E Key are not compatible, I would try to assemble a dual-edge Google Coral TPU. Would it work even if only one of the TPUs is used?
I own a NUC5i5RYH with Google Coral M.2 Accelerator B+M key (coral.m2-bm) with the following setup:
4x cameras
1280x720 @ 12fps
and I get 8.62ms Inference Speed
I was looking like you for a M2 compatible Coral Accelerator and as far as I remember, someone mentioned that only the single B+M key flavour is compatible
My NUC has an Intel Celeron N5105 processor.
Tonight, I set up the detector with OpenVino and the difference has been considerable. Inference has gone from 100-130ms to 20-25. My camera setup is similar to yours, except that I have them configured at 5fps. I will keep investigating, but OpenVino has been a significant improvement.
One question: What inference times did you have before installing the Google Coral TPU?
I remember it was something like 150-200ms
I have 3 cameras, usb coral, detecting at 960x540 10FPS with 7.46 inference. The USB version doesnt perform badly at all.
I have a dual tpu m.2 but its an E key and doesnt work for me. I have a PCI adapter coming, so we will see how that works in comparison.
If it is for wifi it is correct. I use a dual in the wifi slot. Only problem is if the nuc only use one channel on the m2. Then it will be a single not dual. I have an asus pn53.
Hi, I need some help! Iām trying to find a Coral TPU for my Intel NUC8i5BEH, which has a M.2 M-Key spare expansion slot. This company is selling mini PCIe Coral TPUs for $28 each - which is a great price.
Anyone know of a mini PCIe to M.2 M-Key adapter for my hardware? The other option could be a mini PCIe to USB but that seems more complicated. Iāve struggled finding anything on Amazon.
Other useful info: Iām running Home Assistant & Frigate in Docker container.
How did you solve this? Iām trying to do the same.
I havenāt found a solution
why donāt you buy the B+M key variant which is straightforward and doesnāt need any adapter?
The B&M Key version would be perfect but I just canāt find stock of that item anywhere in my region of the world. But Iāve gone ahead and got the USB Coral Accelerator version, Iām sure that will do just fine. Thanks for the tip though.
https://buyzero.de/en/products/google-coral-m-2-accelerator-b-m-key
click on ānotify when availableā next time and get updated for your next project
Subscribed! Thanks
