Hello
I am planing to buy me a coral accelerator because I want to run my surveillance on 5mp main feed.
I have a
Intel NUC Boxnu C7I3BNH Core i3 7100U 2.4GHz Dual Core HD620 2x DDR4 SO-DIMM Max 32 GB/M.2
And want to buy me a coral m2 slot… question is… WHICH ONE?
The M.2 Accelerator with Dual Edge TPU is overkill for 2-4 5mp cameras?
And i have no idea what which one of the 3 fits in y NUC.
I was wondering the same thing, but I ordered the USB version to be safe (and I could buy one from a friend and get it right away). Would appreciate if you would report the result
Wanted to tell you that. They are literally on back order until may 2021 (in my country at least).
But the B&M keys should work fine, but are you willing to sacrifice a high speed storage device
Why sacrifice? i have a ssd in it don’t use the m.2 slot. And it is a server for HASS and backups only.
Would the dual coral work on my m.2 as i read it is a E key and i read to their spec:
“M.2 storage module supporting M.2 2242 and
M.2 2280 (key type M and B+M) modules
Note: Supports key type M (PCI Express* x1/x2/x4 and SATA)”
Are you guys having any luck passing through your Coral USB Accelerators in esxi into HA ?
mine is showing with incorrect IDs 1a6e:089a Global Unichip Corp. therefore Firgate is failing to see it.
