I am pretty technical, but not a programmer. Sonoff does not appear anywhere in the list of devices. I am supposed to install HACS which to me looks like a hack. Or I am supposed to flush my Sonoffy with some other firmware.
All in all too technical for me. I was hoping something more plug & play
Then the project dies. I will not put in danger the integrity of my Synology by opening up root windows and installing things with âdocumentationâ that tell you to do thiungts that do not work.
To many prerequisites for an unexperienced user like me. I really will not install unzip (which makes the first install step stumble), âChange directory to your Home Assistant configuration directoryâ without knowing where it is, stumble over permissions even though I am root.
I have a running Synology and would like to keep it so. This here for $3.50 will also do the job:
Nothing wrong with HACS (Home Assistant Community Store). Take your time and read about it. The name sounds dangerous, but is a typical IT peopleâs jokeâŚ
I use the Sonoff LAN addon within HACS with about 10 Sonoff switches and it works like a charm.
I got it that HACS is an IT joke. The reason why I meant it is a hack is that they really describe it in a way to stop you from installing it. EITHER YOU ARE A PRO THAT KNOWS WHAT HE IS DOING OR LEAVE IT. That is the message they convey.
In the prerequisite: You know how to access the Home Assistant log file
Why donât the tell me where it is?
First install step âwget -O - https://get.hacs.xyz | bash -â fails because unzip is not installed.
They tell you to Change directory to your Home Assistant configuration directory. Found one in ./volume1/@docker/btrfs/subvolumes/270943948ce4f606077210xxxxxxxxxxxxx07335296345e0bc349750de15b/usr/src/homeassistant Is it the one?
They tell you to go inside the container with docker exec -it homeassistant bash but it fails telling me there is no such container
The whole thing is described in a way that only a Unix Hacker can do it. Had my first Unix system on my Desk in 1988 but in 2021 I am not willing anymore to hack around.
for whoever reads this: tested and works. As long as the authentication is not activated. But with no authentication that means the shelly device is open for anybody in the WiFi.
