Which flood light camera with Home Assistant?
i got this flood light camera thinking it can be compatible with HA because it has ONVIF and RTSP… It does not. :frowning:
the PIR is deadly accurate to detect human but no point if i cant get a snapshot and sent to my phone. it does send to a proprietary app CloudEdge but i dont want another app that connects to some cloud.
which flood light camera do you suggest?
most important is human detection via PIR or local AI. then the ability to get snapshot sent to my Telegram. please help.
here are the settings of my existing camera…
found out it can integrate via ONVIF add-on!
but onvif works with port 8000, instead of the default 5000.
i can see the live stream in HA and my NVR now.
too bad all the other sensors within the cam is not available like noise detection, PIR, human detection, or even manually turning on/off the LED.
is there another HACS i can try?
