I have installed Home Assistant with docker on Raspberry PI as per Home Automation Guy you tube.
Everything seems to work well but I now want to backup the configuration and data to a google drive so I have gone with Duplicati (incremental backups)
The issue is I’m not that familiar with HA or containers so I’m not total sure what needs to be backed up ie which directory, volumes, config data, .storage etc Its all a bit confusing ???
I need to stop HA and run the backup as well.
This is my Hassist directory - is this all I need to backup ?
Any help appreciation how to protect my HA install before my SD card fails
pi@PiB:/Hassist $ ls -lsa
total 82616
4 drwxr-xr-x 10 root root 4096 Jun 3 17:53 .
4 drwxr-xr-x 22 root root 4096 May 20 11:33 …
4 -rw-r–r-- 1 root root 260 Jun 3 09:40 automations.yaml
4 drwxr-xr-x 2 root root 4096 May 31 19:04 backups
4 drwxr-xr-x 4 root root 4096 May 20 11:33 blueprints
4 drwxr-xr-x 2 root root 4096 May 20 11:33 .cloud
4 -rw-r–r-- 1 root root 1182 Jun 3 17:34 configuration.yaml
4 -rw-r–r-- 1 root root 1319 Jun 3 17:53 configuration.yaml.save
4 drwxr-xr-x 7 root root 4096 May 28 21:17 custom_components
4 drwxr-xr-x 2 root root 4096 May 20 11:33 deps
4 -rw-r–r-- 1 root root 8 May 20 11:33 .HA_VERSION
16 -rw-r–r-- 1 root root 14011 Jun 3 18:22 home-assistant.log
8 -rw-r–r-- 1 root root 6991 Jun 3 17:06 home-assistant.log.1
0 -rw-r–r-- 1 root root 0 Jun 3 17:07 home-assistant.log.fault
78192 -rw-r–r-- 1 root root 80064512 Jun 5 10:27 home-assistant_v2.db
32 -rw-r–r-- 1 root root 32768 Jun 5 10:31 home-assistant_v2.db-shm
4304 -rw-r–r-- 1 root root 4400192 Jun 5 10:31 home-assistant_v2.db-wal
0 -rw-r–r-- 1 root root 0 May 20 11:33 scenes.yaml
4 -rw-r–r-- 1 root root 3 May 30 21:52 scripts.yaml
4 -rw-r–r-- 1 root root 161 May 20 11:33 secrets.yaml
4 drwxr-xr-x 3 root root 4096 Jun 5 10:22 .storage
4 drwxr-xr-x 2 root root 4096 May 20 11:33 tts
4 drwxr-xr-x 3 root root 4096 May 24 21:28 www
