Which hardware for Input signal
Hi
I am looking for a hardware where I can input the status of 2 floating switch to Home Assistant Node-red to do further automation
What kind of floating switch?
This one?
It looks kind of floaty…
Yes exactly the same floating switch for water level indicator
Water high = OFF
water low = ON
I that case you probably send a voltage through one of the cable and it returns in the other if there is a connection.
But that is only my assumption.
In that case you need to send between 4 and 250 volts DC according to the specifications and put a voltage divider on the receiving end to make sure the ESP-based device does not fry.
So the answer to the question is an ESP, that is my suggestion.
Thanks Hellis for suggetion
ESP is a great choice.
I also found KC868-H4B from Kincony which have 4 input and 4 output relays
I made below design for my project
