Which kind of sensor is on this water meter?
Yep, Esp is 3.3V MCU.
Before you buy sensors, test it with laser pointer if you have. My theory of break beam is only expectation based on your video.
Ok with a laser pointer the light beam seems to be blocked by the the black moving part.
But It should be pointer at the very bottom of the cylinder.
I started using this. Should work on most water meters. ESP32 + $5 magnetic sensor. I have not fully calibrated it yet, but at least I can see when water is running.
And the not black part? Are there 2 transparent windows and two “blocked” ones?
Yes the light seems to pass through on the non-“black parts” spot.
