Awesome. Thanks for the reply.
Iād like to connect with you on this topic. I created something similar without even knowing it was already done.
My heartburn right now, is that thermostat is going to stage 2 (heat for now) quite fast, which I donāt like. Also it gets no time to go back to stage 1 before going idle, despite my setting.
What I am doing is I am ++ 1F the set temp to acomodate for ambient temp raising faster where the tstat is, vs the room calling for heat which is not yet to temperature. I also have dampers BTW
@BO1
I think you might want to check this T6 forum post for info on how to configure a 2 stage system.
My T6 thermostat entity_id is climate.thermostat
In order to get my T6 to have a 1 degree deadband I made the following automations:
automation:
- alias: increase temp 1 degree
##### HVAC actively heating
value_template: "{{ not(is_state_attr('climate.thermostat', 'hvac_action', 'idle')) }}"
condition: "{{ (state_attr('climate.thermostat', 'temperature')|int(0) ) <= 68 and (is_state('climate.thermostat', 'heat')) }}"
- service: climate.set_temperature
entity_id: climate.thermostat
temperature: "{{ state_attr('climate.thermostat', 'temperature')|int(0) + 1 }}"
- alias: reduce temp 1 degree
##### HVAC NOT actively heating
value_template: "{{ is_state_attr('climate.thermostat', 'hvac_action', 'idle') }}"
condition: "{{ (is_state('climate.thermostat', 'heat')) }}"
temperature: "{{ state_attr('climate.thermostat', 'temperature')|int(0) - 1 }}"
The increase temp 1 degree
automation checks when the thermostat changes from the idle
state, by looking at the climate.thermostat
:hvac_action
attribute, and it raises the thermostat setpoint by 1 degree, which makes the thermostat keep heating to 69 degrees. As soon as the thermostat goes back to the idle
mode, the reduce temp 1 degree
automation changes the thermostat setpoint to 68 degrees.
I donāt remember why I have the condition to check if the temperature setpoint is <= 68 degrees. It might not be necessary. I think it was so it didnāt conflict with the opposite automation that I have for cooling, which changes the setpoints in the opposite direction, but the check for the thermostat being in heat mode should cover thatā¦dunno.
Anyway, if your thermostat entity_id is climate.thermostat
this will probably work to create a 1 degree(ish) deadband. You can adjust it to 2 degrees by changing the temperature: "{{ state_attr('climate.thermostat', 'temperature')|int(0) + 1 }}"
lines to +/- 2.
This is a graph of some recent data (itās been cold): Blue is air temperature, Orange line is thermostat setpoint, Orange shading is thermostat in heating mode.
The thermostat is set to 68, but sometimes it turns on before the air temperature hits 68 degrees because itās āsmartā and is guessing that the air temperature is about to drop to 68 degrees. As soon as the thermostat turns on the heat, the automation changes the setpoint to 69 degrees, but the thermostat keeps heating to 69.5 degrees because it does what it wants.
side note:
I also have the automation set the fan to āLowā for a few minutes after the heat turns off because the thermostat canāt seem to do that and thereās still residual heat in the furnace to blow around the house.
Thank you.
I know this is an old post, but in case anyone gets here through google like I did:
You can set the cycle rate through the Installer Setup Options menu on the thermostat itself and it works. If you google āTH6320ZW2003 manual pdfā the first result is a version of the manual with all codes needed for 2 stage heating/cooling, cycle rate, etc.
