I am trying to install HA Supervised on a Raspberry Pi 4 with Bullseye 64 bit OS. Following the instructions, I am a bit confused as to which one to choose.
Thank You,
actodd
Thank You,
actodd
Hi Actodd,
Did you get any further? I’m installling Home Assistant Supervised on a Pi 4 using Debian Bullseye, but when I enter this command:
dpkg -i os-agent_1.2.2_linux_armv7.deb
I get response:
dpkg: error processing archive os-agent_1.2.2_linux_armv7.deb (--install):
package architecture (armhf) does not match system (arm64)
Errors were encountered while processing:
There is an arm64 download, but it’s a .tar.gz, not a .deb file. Extracting and installing it doesn’t work unfortunately (in the .tar.gz file is an os-agent file without extension)
