Which peephole camera with HA?
Hi everyone,
I’m looking to have your opinion about the different peephole camera that exist and their integration with HA.
Did you try some ?
Thx
Would be interested in a solution here as well. Ideally, Wi-Fi + battery powered, since I don’t own the flat in which I am living at the moment and want to mount it to the door from the inside.
I’m just using a Pi Zero with RPi Cam Web Interface. That has a URL that is just the feed without all the controls. I’ve just put that into an iFrame. I haven’t nailed the battery situation yet as I use mains power but the best I had when I tried it was about 24 hours using a 20,000mah power bank.
No solution ready out of box instead ? :slight_smile:
That seems to be quite a power drain to be honest. I was hoping for something like the regular cameras that have like a year or more in battery life. I was thinking about the Pi0 as well though, so thanks for the input.
This one on alibaba seems to be perfect solution…
https://www.alibaba.com/product-detail/1-78mm-Lens-1080P-Home-Security_60749761735.html?spm=a2700.details.maylikehoz.2.2ff31cfaHG2fVw
I found this. But dunno if it can be used in HA
https://www.edimax.com/edimax/merchandise/merchandise_detail/data/edimax/global/home_network_cameras_indoor_fixed/ic-6220dc/
EDIT: It seems RTSP compliant.
