Hi Guys,
I’m new to this forum and I hope you’ll be able to support me a little bit with my beginner question😀. Many thanks upfront!!
To my situation, up to now I use the mihome
App. I have a few aqara door sensors, motion sensors and a aquara gateway. Recently I bought some yeelight bulbs and ran into trouble installing them since the aqara things work only on china server while the other run only on local europe severs. This brought me to Home Assistant which I already installed on a Synology Station.
While trying to add the gateway and bulbs I learned that the aqare hub generally is not supported and the yeelight bulb is not integrateable anymore since a firmware update. To solve the hub issue, I plan to buy a Conbee 2 USB Stick. So I’ll be able to use the sensors at least. No hope to use these bulbs…
Looking into the future - and this is my question - i’m concerned which component I should go for when extending the smart home (more sensors basically). Could it also happen that not only the bulbs are eliminated from use but also the sensors? Which sensors (manufacturer) would you recommend, if you would buy them now? I mean the aqara are cheap and work fine with the mihome app, but who knows… is it (technically) possible that these and other sensors might be affected by a firmware update similar like the bulbs and cannot be used with HA anymore?
So thanks for your advice/recommendations.
Regards.
