HA_n00b
(HA n00b)
May 18, 2023, 6:48am
1
I am looking for a temperature sensor so I can check the room temperature and humidity.
Which brand and model would you recommend?
I’m looking for one which has:
accurate reading
good battery life
reliable
compatible with ZigBee via mqtt
not too expensive
My plan is to setup automation to turn on or off airco when the room temperature is X degree.
francisp
(Francis)
May 18, 2023, 7:05am
2
I have Xiaomi 's. Batteries lasted 2 years before I had to replace them.
I use the aqara. Very small and reliable. IN best case pair them at the place where they will be positioned
koying
(Chris B)
May 18, 2023, 10:02am
4
Those are the latest I bought. Fine so far
https://fr.aliexpress.com/item/1005004741554968.html
Just out, didn’t try:
are you happy with their accuracy ?
HA_n00b
(HA n00b)
June 20, 2023, 12:10pm
6
I bought 3 and it seems they work fine with HA, but I have no idea how to check if they are accurate
I compared against digital thermometer which I have and the results were similar, so I think they’re accurate.
Did you use a gateway with them?
izab
(Isabella Borgward)
February 4, 2024, 5:07pm
8
I use my Aqaras with deConz. That’s my “hub”.
Thank you!
Does this mean that you don’t need more hardware than the Raspi? As I understand this must run on a PC?
izab
(Isabella Borgward)
February 5, 2024, 4:05pm
10
I run HA and deConz on a PC but I would think you could run both on a Raspi.
Yes, deConz will run on Pi.
https://phoscon.de/en/conbee2/install
Thank you!
Great, now i’ve learned a lot.
Gunther_V
(Gunther)
January 10, 2025, 8:03am
12
Hi Chris, got the same , but how do you integrate them in HA ?
Got 3 different aqara models for zigbee, all of them terrible, not accurate at all, bad signal.
Trying to find some proper ones…
The only reliable ones I have are super old 433 based ninjablocks humtemp sensors which last forever, even outdoors!
Would love to see a proper review of such sensors with proper tests…! Maybe a video idea for andreas spiess
mechkbfan
(Andrew Bowen)
February 5, 2025, 9:44am
14
I’m having this issue now.
Had SkyConnect with Aqara and they seemed great but then had one recently stall.
Trying Sonoff Zigbee 3.0 USB Dongle Plus and it seems even worse with Aqara. 10min reporting intervals and no battery status.
You find a better combination? Contemplating going Tuya WiFi ones even though I dont want to install their app.
