Which Wired wall physical switches for european standard
Hello!
Like in topic. Which switches do you recommend? I read about:
-sonoff touch (but I prefer physical key, not touch) I heared it can be tricky to touch in dark
-xiaomi aqara wall switch wired ( but I hear they cant fit into wall, because they are square not round like european standard)
Is there anything else What can be used in this way? :slight_smile:
I thought about Smart bulbs also, but I cant image that I must turn off or turn on light only using smartphone, without another possibility.
I know its possible to use wireless aqara switch, but where to stick it? On the psyhical switch, which must be always turned on? I would look ugly :smiley:
sonoff requires neutral wire in your swithcbox which you might not have
aqara uses a different standard, EU has round switchboxes and aqara’s are square Type 86.
you can look into shelly as an option, I don’t use them personally so I don’t have any more info
I combine my 2 Yeelight Ceiling lights with aqara and xiaomi wireless switches, but in practice smart switches are better than smart bulbs
