Which Z-Wave Lock Add-in? Keymaster? Keymaster Basic? Simple Lock?
Looking to integrate and have better control of 5 Kwikset 620 Z-Wave Locks but the basic interface is somewhat lacking as I suppose is well known.
Doing my due diligence, I’ve come across three Ad-Ins and maybe there’s more but I’ve found:
Basically, I want to be able to have multiple PIN’s for family, close friends and our house cleaners with a set day and time for access. I also want logging so I know who is in our house and when they’re in our house.
I’d eventually want to possibly do some geofencing to have the locks automatically lock when nobody’s home and have some automation to turn on lights when the lock is opened at night.
Any suggestions or reviews would be greatly appreciated.
For some background information, I’m a recent convert from Vera Plus after 10 years to HA. I’m running it in an Oracle VirtualBox under Windows 10 on an old i3 NUC I’ve had in a box for several years doing nothing. I’m using a Zoos Series 800 Controller, model ZST39 LR on the latest f/w 1.40 which I flashed on the stick yesterday. I’m relatively comfortable doing basic coding given good instructions but am by no means fluent!
Because I’m a new user, I’m limited to one link per post so here’s the other’s I’ve come across:
And I have to wait 5 minutes between posts.
Any way to fix that? I’m not a spammer and am legit. You’ll see me on a lot of forums; just not this one yet!
And lastly:
Well, I’ve proceeded down the path of installing HACS and Keymaster. Now I’m stuck as the Keymaster Addin is not functional.
My configuration.ymal:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
  packages: !include_dir_named packages
I have the packages folder but there’s nothing in it:
I’m stuck here:
“Open HACS and select the Integrations tab. Click the + icon at the bottom right and search for lock-manager . You will then get a message that the integration requires Home Assistant to be restarted. Please do so.”
I’m not finding an Integrations tab in HACS.
Well… I turned to Youtube and got a great set up video. I was doing it correctly but for whatever reason it wasn’t showing up. I’ve got it going now though.
got a link to that video? In the process of setting this up myself. What was it that finally got things working for you?
I believe it was this. One thing I’m not happy with about keymaster is the inability (or at least, I haven’t found it) to add additional door lock codes or to get notifications when users with codes unlock my doors so I can track whose entering my home. I found the built-in lock code generator in my VeraPlus to be much easier to use and much easier to customize.
I spent about 2 hours last night installing and configuring Keymaster-Basic. MUCH easier (and actually works!) than Keymaster. I modified the dashboard to better align with sections (new Lovelace) and added a 9th slot. All were simple to do and it just works now.
I’m going to look (a little) at the templating to see how to get past the 9 device limit, or if there’s a blueprint/scripted approach that could be used. Since I don’t need more than 4-5, it’s not a very high priority.
Hope this helps!
@bcjmk Bless you and your comment. My Keymaster integration wasn’t working and wasn’t looking forward to figuring it out. Keymaster-Basic had me up and going in less than 20 mins.
Yeah I spent a while figuring out some data logic but tripped up on the maintenance piece. There’s not an easy way to enable input without 5-8 helpers for each lock slot. Even had an approach to support multiple locks
But it was getting dodgy.
I got my approach to work with 5 generic inputs but it was pretty klunky. I wound up extending Basic to 15 available slots and created a markdown summary card
Glad I could help someone.
