I’ve just ordered a BeeLink Mini S12 Pro that I’m planning on running HA on through Proxmox. I’ve been reading up on HA a lot this weekend and have made the decision to switch from HomeKit due to the possibilities that it gives.
One thing that I still don’t quite grasp is which ZigBee module I should get if any. I currently only have IKEA lights and their Dirigera hub which I guess would work for now but that it would be limited to IKEA products. So if I understand correctly I could keep using that hub for now and switch whenever I buy another ZigBee device or make the switch now in order to not have to redo everything with something else later on?
I’ve currently looked into the zbdongle-e, zbdongle-p and the HA Connect ZB-1 but don’t know which one is the better choice? I’ve read that the -e is most powerful but might be problematic?
Which one do you guys recommend? And I’ve understood that EMI can be an issue but how much so? Can I have the dongle on a USB extension cable in an IKEA cabinet where a Ubiquiti AP also will live? Or would it be better to have it inside a metal media central where my Dirigera hub currently resides? Those are unfortunately the only two options atm.
Thanks in advance!
