Which Zwave for Schlage BE469 series locks?
So I am wading into Zwave…again (Not looking forward to it.) I have an Aeotech Gen 5 z-stick and a Schlage Connect lock (BE469 series). Before I haphazardly spend an entire weekend trying different installs to get this working I have some simple questions:
Which is my best install path?
OpenZwave (deprecated)
Zwave (deprecated)
ZwaveJS
or
Zwave2MQTT?
(My HomeAssistant install is Debian 11 Supervised (Core is 2022.2.8) on a plain vanilla X86/64 lenovo office grade desktop, NOT HomeAssistant Core in Docker). My Z-stick is factory reset, not installed & I have a USB extension cable ready. Once I get that installed, I will factory reset my lock and attempt a pair. Other additional zwave device will be a door sensor (still in box, awaiting install).
ZWaveJS is the way forward. The others are no longer in development. Id suggest actually installing ZWaveJS2MQTT (but dont use MQTT). This gives you a nice config panel to troubleshoot things.
I have a BE469 (old version) and a BE468 (I think). They both work fine and I can monitor events to get lock code entries for automations.
Sold! ZWaveJSMQTT. Now to look for a goodHOWTO/ walkthrough to set THAT up from scratch…
Just install docker image
docker run --rm -it -p 8091:8091 -p 3000:3000 --device=/dev/serial/by-id/insert_stick_reference_here:/dev/zwave \
-v $(pwd)/store:/usr/src/app/store zwavejs/zwavejs2mqtt:latest
Turn off mqtt in zwavejs ui
Add zwavejs integration to your HA
You can install using these methods also
