Hello –
I noticed after recently updating Home Assistant (it is current as of 6/18/23) that the Whirlpool integration stops working. I have uninstalled and reinstalled the integration which did not help. I noticed re-loading the HA gets it working, but at some point it will stop working. I don’t see nothing in the logs, but perhaps soon I will as I enabled debugging. Help appreciated.
hawkeye76
(Scott Hawks)
June 28, 2023, 2:30am
2
I have the same issue. I raised an issue on github with authors. they are looking into it. appears to be an issue on Whirlpool end.
opened 10:42PM - 24 Jun 23 UTC
integration: whirlpool
### The problem
The whirlpool integration keeps "losing connection". it will wo… rk for a little while, then just stops working. Reloading the integration fixes it, but only for an hour or so.
### What version of Home Assistant Core has the issue?
core-2023.6.2
### What was the last working version of Home Assistant Core?
core-2023.5.x
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Whirlpool
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/whirlpool/
### Diagnostics information
[home-assistant_whirlpool_2023-06-24T22-41-19.678Z.log](https://github.com/home-assistant/core/files/11858350/home-assistant_whirlpool_2023-06-24T22-41-19.678Z.log)
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
I see this in the logs:
Logger: whirlpool.eventsocket
Source: runner.py:179
First occurred: 11:33:11 AM (14 occurrences)
Last logged: 4:00:00 PM
Stopping receiving. Message type: 256
See this as well (although maybe not related):
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/http.py:53
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 3:47:12 PM (1 occurrences)
Last logged: 3:47:12 PM
[547130810384] Disconnected: Did not receive auth message within 10 seconds
### Additional information
_No response_
