I have problems with Whisper and ‘Homeassistant Satellite’. The satellite (GitHub - synesthesiam/homeassistant-satellite: Streaming audio satellite for Home Assistant) was installed on a PI3B and worked correctly once or twice. Then he loses the connection to the Home Assistant. The ADD-On “Whisper” then displays the following message in the log:
[09:50:25] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
INFO:wyoming_faster_whisper.handler: accusations.
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name='Task-316' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError('Connection lost')>
File "/usr/local/lib/python3.9/dist-packages/wyoming/server.py", line 35, in run
if not (await self.handle_event(event)):
File "/usr/local/lib/python3.9/dist-packages/wyoming_faster_whisper/handler.py", line 45, in handle_event
await self.write_event(self.wyoming_info_event)
File "/usr/local/lib/python3.9/dist-packages/wyoming/server.py", line 26, in write_event
await async_write_event(event, self.writer)
File "/usr/local/lib/python3.9/dist-packages/wyoming/event.py", line 114, in async_write_event
await writer.drain()
File "/usr/lib/python3.9/asyncio/streams.py", line 387, in drain
await self._protocol._drain_helper()
File "/usr/lib/python3.9/asyncio/streams.py", line 190, in _drain_helper
raise ConnectionResetError('Connection lost')
ConnectionResetError: Connection lost
future: <Task finished name='Task-317' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError('Connection lost')>
INFO:wyoming_faster_whisper.handler: Schalte in die Erzweine.
INFO:wyoming_faster_whisper.handler: Schalter Adieu West-Walika ein.
future: <Task finished name='Task-377' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError('Connection lost')>
INFO:wyoming_faster_whisper.handler: Wann ich?
future: <Task finished name='Task-611' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError('Connection lost')>
INFO:wyoming_faster_whisper.handler: Nuh!
future: <Task finished name='Task-782' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError('Connection lost')>
After restarting the add-on, everything works fine again - until the next crash.
HA and the addons are up to date.
Anyone an idea?
greeting
Michael
Addendum:
apparently Whisper misinterprets certain commands and then crashes
