I’ve been trying my hand at the local voice control in HA.
I’ve followed Everything SMart Home’s guide and go to the point where I am just testing it through the Lovelace dashboard on my PC and phone.
The problem I have is even if the assistant correctly works out what I am saying the speech-to-text takes in the region of 30 seconds.
My HA instance is running in a LXC container on my Proxmox server, in case it was a processing power issue I upped the allocated cores to 8 and gave it 8GB ram.
When processing a command I can see the CPU usage of the LXC is hovering around 50% so this suggests there is plenty of processing power available.
Are there any setting I should be looking at to improve the speed of this? I’ve tried changing the model and have checked that is it set to English.
Thanks.
