White screen with Blue bar when upgrading to 0.79.3
After an upgrade to 0.79.3 from 0.78.3, I simply get a white screen with a blue bar.
I tried rolling back to 0.78.3 but it still doesn’t work so I’m at the point of either getting this fixed or scrapping and reinstalling.
Hopefully this is fixable.
Here’s the error I get when I try to access the page.
2018-10-03 15:20:20 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.5/dist-packages/aiohttp/web_protocol.py”, line 390, in start
resp = await self._request_handler(request)
File “/usr/local/lib/python3.5/dist-packages/aiohttp/web_app.py”, line 339, in _handle
match_info = await self._router.resolve(request)
File “/usr/local/lib/python3.5/dist-packages/aiohttp/web_urldispatcher.py”, line 799, in resolve
match_dict, allowed = await resource.resolve(request)
File “/usr/local/lib/python3.5/dist-packages/aiohttp/web_urldispatcher.py”, line 281, in resolve
match_dict = self._match(request.rel_url.raw_path)
File “/usr/local/lib/python3.5/dist-packages/aiohttp/web_urldispatcher.py”, line 406, in _match
for key, value in match.groupdict().items()}
TypeError: build() got an unexpected keyword argument ‘encoded’
The first thing to try when problems like this occur on an upgrade is to do a force reload (ctl + f5) in the browser, which normally clears things up.
With the new auth system, it is also worth trying to clear any cookies or data associated with HA in the browser.
I have the same issue on all ipads. (I know they are using 9.3.5) I’ve also cleared all settings from safari, but it didn’t make a difference. Still only getting a blue bar when accessing the web interface from the app or from Safari.
This was happening in all browsers.
I also had trouble with the alpha of the haclient for Android… it wouldn’t connect.
I cleared out cache… force reload… etc.
This is the second time an upgrade has gone wrong enough to force me to reinstall.
I gave up on trying to fix it and decided to use this as an excuse to load up the docker image on my Synology.
I’m running the docker image in unraid, so version 0.79.1, this is really frustrating me now.
I’m getting the same results with opera browser on the iPads. (Three iPad 2’s)
