Whitelist IP ever implemented?
Has this feature been added yet? I couldn’t reply in the other thread.
Whitelist IP
Not in docs.
No
You may be able to creat a sensor that look in the ip_bans file and use automation to call script that removes it.
Or
Search for something like this
While possible, there are not many unavoidable circumstances where you ban your own IP. In many case if you do you can just switch to another WiFi or cell network to regain access. I’d be more concerned about whitelisting a bad ip. I haven’t thought through this so. Whats your concern with this?
Look at Add ip_ban_whitelist for HTTP Integration
You can also go here and vote up the one there, or start one if it isn’t there. Reference the one you pointed to and the link I gave you as a helper… home-assistant · Discussions · GitHub
Thanks… I did vote :slight_smile:
