In-wall physical dimmer switch I am having trouble finding that has these properties -
- smart (WiFi) and compatible with HA,
- does not require a hub,
- can be used with an original antique wall plate that we want to keep (so if not toggle it must be able to fit through the slot such as a rotary nob or the like)
- does not require a neutral
- I am in the USA, it is 120v AC, and regarding the load it controls a ceiling light that is three (currently LED but I can switch to incandescent) bulbs
