Hello Everybody.
I had for some time my Voice Assist triggers in the configuration.yaml.
Some things are not so convenient for me that way so I switched in some automations to a trigger “When a sentence was said” (I have it in german, maybe it is slightly different in your english inst)
My configuration is
- Assist Microphone AddOn with an Anker PowerConf S330 Analog Stereo as suggested earlierdays in some Wiki.
- Speech-to-Text is the Nabucasa.
- A Tasmota ESP32 door-motor on my ground entrance which I can open with the sentence “Open the door”.
Everything is / was working fine.
In my automation I have a Media-out stating “Of course, I will open it right now”.
But in the mid of this sentence somebody shouts D O N E !!
Deactivating the automation / trigger in the automation, the result is “Sorry, I couldn’t understand that” which sounds feasible. Nothing else, no DONE!. Nothing.
The thing is: In assist microphone, there is a field “Done Sound*” with the explanation "Path to WAV file to play when voice command is finished (empty to disable). And this is as empty as a field can be.
I restarted, rebuild the add.on, uninstalled-installed, rebooted the server… it still says Done to me. Not only that, it SHOUTS out LOUD on top of any other media-out.
My shared-folder /share/openwakeword does not contain any done.wav.
Any help appreciated. Jörg Hopmann
