File "/usr/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 95, in async_script_delay
self._async_listener.remove(unsub)
ValueError: list.remove(x): x not in list
and
WARNING (MainThread) [homeassistant.core] Unable to remove unknown listener <function async_track_point_in_utc_time.<locals>.point_in_time_listener at 0x727c46f0>
which i cant place at all, nor have any idea what they mean, I searched for listeners in the Hassio interface, and lo and behold, here they areâŚon the dev-tools event page
Is there any way to tell which entities (if they are entities) this is referring to? and to which event they are listening?
I suppose this is about automations and customizations reading states and then doing something? It would be really helpful if there would be a way to explicitly identify these listeners. Is this available in the toolbox, or would it be possible to write a (python)script or so to do so?
Itâs a warning, the listener could have already been removed by another event or the listener ended. To identify it, you may want to turn your logging on to âINFOâ. Then watch all the events that occur in front of this warning. Whatever occurs before most likely leads to that warning.
âŚaaaand same thing in my situation. it would be pretty helpful to have a possibility to identyfiy those âunknown listernersâ by the hex address (I guess?) thatâs given in the warning log, especially that it looks like itâs changing every line⌠0x7ff33dbe6b90, 0x7ff33be140e0, 0x7ff33de12cb0, 0x7ff33de1add0 (and I can go with that for a looong time)
Its changing every time because itâs a new object. I.E. a new listener. You can safely ignore these unless ram is slowly creeping up on the system. As stated before, you can identify this by tracking previous events. If you turn on DEBUG you may be able to catch a debug statement that links to this to identify the problem, or see if it actually is a problem.
tried with more verbose log. the only thing that showed couple of times was
INFO (SyncWorker_5) [root] Sending control command: KEY
which is connected with samsungtv integration AFAIK (at least thatâs what Iâve found here) but Iâm using samsungtv_custom so Iâm not sure itâs related.
is it plausible that itâs the source of the listener? (Iâm away right now, so canât test too many things in the configuration, donât want to risk that âhome will go downâ and I wonât be able to physically reboot it ;))
