I have fairly large garden / yard (27x70 meters) and now it has no lighting.
I am starting almost a blank page for this but I have a couple of objectives and a few situational advantages but also some concerns.
Objectives:
- Helping security cameras. I have good security cameras that are pretty good but they struggle in the depth of the night to cover the edges of the property. i.e. somebody drilled out my gate chain in between 2-5am.
So to help that I need a few lights that are 3000K or warmer to kick in in those hours and run for long periods of time. - To not need a hand torch in the evening. If am going to a shed or the gate or just coming in late at night because of dense trees (including firs and pines) I really can not walk without a flash light.
To fix that I would need some lights that I could control based on presence or via HA automations.
Advantages:
- Powered structures in the ends of the property. I have garage and a shed that are on the opposite sides of the property and have mains power in them, so I can power or attach things too it.
- Re-fencing. I will need to build a new fence, soon and I could burry a wire along the perimeter of property/fence for some lighting.
- Recycling. I after some other work I have some outdoor light bodies with E27 sockets…
I was considering two options:
a) Fence lighting. I can put low voltage DC transformers and relays in the buildings and run a line around property.
b) Solar + battery in the trees. Using wireless for switching and some some smart bulbs in old enclosures and hanging them in the trees.
Concerns:
- Wireless reliability. Since there is a lot of vegetation, a longish range (50 meters from the house in the furthest point) and the house has metal roof. I am not sure if wifi or zigbee will reach the lights to turn them on and off reliably.
- Wired longevity. I saw some wired solutions that advertise “no soldering needed” clip ons that clip into wire with teeth that penetrate the isolation. Am I being paranoid or is that a really bad idea. (It gets really wet in spring or autum so wire would effectively be submerged if placed underground)
