Whole Home Water Shutoff system
I am looking for a whole home water shutoff system that runs with no cloud requirement. As I am having a salt softener system installed in my home, a plumber will need to do some work with the pipes coming into the house. I’d like to take advantage of that to install a whole home water shutoff that integrates with Home Assistant. I’ve seen several discussions about some great systems (like Zoos). But I’d prefer an inline solution vs. an actuator that turns the handle. Why? I’m not really sure…I just suspect it is more reliable to have a ball valve…but I guess it’s no different than the Zoos Titan. What are your thoughts? I see a lot of positive reviews of Zoos Titan, but I’ve also previously used a U.S. Solid Motorized Ball Valve connected to a simple Zigbee outlet for an outdoor sprinkler, so I am not afraid of that approach. What I don’t want is a dependency on the cloud…local (zigbee or zwave is my preference). Of course I want to be able to use it with simple wireless leak sensors and via a HA automation/routine. Any thoughts or experience is appreciated.
Are you interested in a system that can (itself) detect leaks via flow-meter, or are you looking for a shut-off solution on your main line that’s triggered exclusively by separate leak sensors?
It sounds like that latter, but that clarification will help focus answers/suggestions here for you.
I see no need for constant communications like Zigbee or Zwave. Use a LoRa based solution. Battery powered like a D Cell. It will last > 1 year because you may use it occasionally.
I use this: UseeLink Matter Water Valve and some floor leak sensors. I also have an automation that cycles the ball valve off and on once a week, just so it doesn’t get stuck in the on position.
Hey, I use the Watergate Sonic. Hero Labs used to be Herolabs (which is what the intigration in homeassistant is called.) Works really well and gives a lot of information about the water. it fits inline so definatly requires a plumper but can recomend the system. works really well.
HA intergration wise, the offiicial intigration in does use cloud but i think @markvader was was working on a version that would only use local using the herolabsapi python library.
The system comes in 2 parts, the valve itself and a tiny hub. i wouldn’t usually go for a system with a hob as well but made an exeption for this as its installed at the back of a packed cupboard with a big metal sink on top of it so the signal wouldn’t stand a chance without a booster. Having the hub plugged in close by gives the valve a fighting chance at staying connected and to be fair its been really reliable.
I’ve got an review on my website if you want to take a look:
This was before i had it intigrated with HA so if your interested i can update the review with the HA capabilities too.
Hope that helps and gives you a potentual option.
Thanks!
This works well for me - YoLink FlowSmart All-in-One Ultrasonic Water Meter - YoLink FlowSmart All-in-One Ultrasonic Water Meter, 0.75“, YS5018 | User-Set Auto Shutoff, NSF Certified, Water Usage, Up to 10-Year Battery, LoRa YoLink Protocol Up to 2034 Feet, Hub Required - Amazon.com - it is LoRa (so it does require a hub). Not only does it allow you to shut off the water, but it measures the flow and water temperature. I am not super handy with plumbing myself, but with 2 Sharkbites, it only took me about 20 minutes to get installed and running.
I have the Zooz Titan. Seems to work fine.
I think having the actuator is better as you can always take it off later and manually run the ball valve. It’s kind of like smart light switches where it’s always good for them to still work when HA is down.
I have mine on 1" copper. It’s installed inside the garage where I already had pluming available. Someday I’ll move it outside the house.
I have a bunch of Zooz ZSE42 leak sensors, too. I found where a faucet gasket was leaking with one. I have automations to check that they have been “Last seen” to make sure they are still reporting, as well as weekly battery checks. Every media player in the house goes off when a leak is detected and the valve shuts off. That was a jolt one night.
I have a Droplet water flow sensor, too. And a water pressure sensor.
Nothing to be too proud of, but it works… I just wonder why the electrician thought that was a good spot for an outlet!
Nice install job on the ESP32 hanging mid-air, right?
I’ve got pretty much the same set up as you just laid out differently.
I use a Dome Zwave add-on ball valve actuator, a waterdrop flow sensor, a few leak sensors in the basement and under sinks and I just installed a water pressure sensor.
I like the idea of the addon actuator as you said if it fails I can just bolt on another one and don’t need to re-do any plumbing. Which would be a pain since it’s the first thing in my plumbing supply line and I’d need the city to turn off the water to replace it.
Great question. I guess I would prefer a system that can auto-detect leaks via flow monitor vs. separate leak detectors as that seems a more intelligent approach, but I also want a completely local system. My understanding the flow monitor system like moen requires a cloud setup…but perhaps there are local options as well I am unaware of.
I’m a big fan of Titans - lots of great features (including regular cycling of the valve) - I have one one our main line and one on our water heater. But I’d be leery of putting them on PEX, so that’s a consideration if you don’t have copper where the valve is.
But a valve-actuator solution is only as good as the leak sensors tied to it – how many of those are you willing to scatter around your house? Then what about a failing fitting or pinhole leak in the wall or whatever other place you don’t happen to have a sensor?
A few years ago, I got the chance to get a Phyn Plus installed at cost, so I jumped on it… There’s a community integration for Phyn in HA here that rocks – it’s awesome. So now I have both Phyn and Titan in play, which is a nice safety blanket. The Phyn does a nightly pressure check on my system to ensure there are no leaks anywhere, and I really dig that. The HA integration enables me to automatically activate its Away mode (more aggressive detection) whenever we’re not home, which is another nice win.
I like the Phyn since it uses ultrasonic sensing for flow (no physical impeller in the pipe to worry about getting stuck or breaking apart). But, yeah, it’s cloud-based – I don’t have any illusions that that plug could get yanked (or get put behind a paywall) at any time, but I’ll cross that bridge if it comes.
the issue you will have is that a flow monitor will usually not be sensitive enough to catch a small leak (that can still cause big damage) and it will be hard to tell the difference between a medium leak and legitimate water usage.
It’s best to use leak sensors as you can put them where ever it makes sense that you don’t expect water to be during non-leak conditions.
if you go with zwave or zigbee that will be local and the sensors are fairly cheap.
I use an EVC200 from EcoNet Controls. Z-Wave; no cloud. It turns the valve; I also like it being an add-on control that doesn’t absolutely require smart-home system for regular house operation. Using lots of leak sensors --under every plumbing fixture and water-using appliance. I wish I had gotten all sensors with leak-detector cord (vs. those with just two probe points).
Only failure I’ve had is puppy running off with leak sensor in her mouth …
I have a Phyn and am overall happy with it. A buddy won it at work and didn’t want it so I got it for free and I installed it myself. I’ve had it 3ish years now. It is cloud based and I too am not a fan of that.
Because I obtained mine for free I didn’t shop around or do any research. I just installed it and connected it to HA. Our Phyn has been great and I value the nightly pressure checks.
We quickly discovered that you need both the shut off device (Phyn) and leak sensors. Yes, the Phyn will shut off the water in a sudden catastrophic leak, but only after 10ish gallons or so have sprayed everywhere. Is that better than dumping thousands and thousands of gallons of water while you are away…yes. But a simple water leak sensor in places with known failure points (water heater, sinks, washer…) tied to an automation that turns the water off after a gallon or 2 of water makes the system priceless.
Someday our Phyn will die, and hopefully not for a least a decade. But I am curious what device you will buy and if you find a local only device the meets your needs. Please update this post a year from now and let us know.
Jeff
How does it know the difference between a “sudden catastrophic leak” and you turning on a water spigot fully open when for example watering the garden?
What I’ve read is it learns the patterns of turbulence / volume a given spigot generates and then takes an educated guess. 95% of the time it is correct but there are times when it is wrong. It took a long time for the device to learn our water use. Including asking us “what just used water, give it a name and tell me if it was a toilet, sink, shower, dishwasher…)”. At least for the Phyn, we had to help train it.
This has worked well overall but there are times when its guess is annoying! Ex: I am in the shower and my husband is watering the garden. It will send a push notification saying it is detecting unusual water. If we don’t reply, it will shut the water off. It has gotten better over the years but it can’t know everthing. This happens 2-3 times a year. After it shuts the water off you can go into the app and tell it if the water use was normal, and what it was. In hopes it will learn from this.
We set the Phyn to away mode when we leave the house. That worked well for 2+ years until we added a cat water fountain, it INSISTS weekly we have a slow water leak and shuts the water off. I go into the app and say “no, this is expected water use, its a water fountain.” But, it keeps shutting the water off. Our options are to accept it feels it is detecting a leak while away, or disable our automation of putting the Phyn in away mode when we leave the house. *we don’t need to use away mode, but it is way more responsive to shutting off the water if a pipe breaks.
Thanks for this reply. I think this one offers me the best option. I like that it is inline, no cloud, uses LoRa (though range is not an issue), operates independant of power or internet, and can shut off automatically when it senses a leak…but can also pair with sensors. Any downsides I am missing? I have copper pipes, but since I am having a plumber come out to install a whole house water softener, I am not worried about installation as a plumber should have no issue with it.
That looks like a good one. Thanks for sharing.
That would only happen once and my wife would be calling the plumber herself to have it removed.
:laughing:
I have the Sinope Sedna VA4220ZB (it’s Zigbee…they do have a WiFi version). It has been super reliable and has a battery backup built in!
My only issue is I purchased and installed the flow meter with it, but in HA, it takes some ZHA quirks and other things to get it enabled with the valve–and I’m not sure the flow rate is shown right.
