WHT: Why does Visual Studio Code is throwing an error about not supported DeviceClass?
Visual Studio is telling me, that some of the device_classes I have set for some sensors are currently not allowed.
It is providing a link with more information, where the device class which I am using IS listed…
- sensor:
    - name: oilfox_fuelused
      unique_id: 'oilfox_fuelused'
      unit_of_measurement: L
      device_class: volume
      state_class: measurement
      state: >
        {% set max_filllevel = 1000 | float(0) %}
        {% set current_illlevel = states('sensor.oilfox_filllevelquantity') | float(0) %}
        {% set fuelused = max_filllevel - current_filllevel | float(0) %}
        {{ '{:.2f}'.format(fuelused) }}
  - sensor:
    - name: odometer_custom
      unique_id: 'odometer_custom'
      unit_of_measurement: km
      device_class: distance
      state_class: total_increasing
      icon: 'mdi:speedometer'
      state: "{{ states('sensor.odometer') | float(0) }}"
VS Code is reporting:
Sets the class of the device, changing the device state and icon that is displayed on the UI (see below). It does not set the unit_of_measurement.
https://www.home-assistant.io/integrations/template#device_class
Value is not accepted. Valid values: "apparent_power", "aqi", "battery", "carbon_dioxide", "carbon_monoxide", "current", "date", "duration", "energy", "frequency", "gas", "humidity", "illuminance", "monetary", "nitrogen_dioxide", "nitrogen_monoxide", "nitrous_oxide", "ozone", "pm1", "pm10", "pm25", "power", "power_factor", "pressure", "signal_strength", "sulphur_dioxide", "temperature", "timestamp", "volatile_organic_compounds", "voltage".yaml-schema: http://schemas.home-assistant.io/configuration(1)
but this is not the complete list according to this documentation:
The VSCode extension schema needs updating.
I have read the Wiki… but it does not give instructions on HOW to do what it is saying to do… just that it needs have npm run done with it… I have no idea what it is telling us to do…
If you can’t figure it out, it’s not meant for you to update. This page is for developers trying to update the schema. You as a user would just update the extension in VSCode when a new release appears. Typically, VSCode auto-updates extensions by default, so all you’d have to do is wait for a fix.
