Lovelace appears to filter out any sensor of device_class: battery
when presenting a default dashboard.
Default dashboards will display any custom groups, including all of their defined entities, even if they have an entity status of “hidden”—except for sensors of device_class: battery
, which won’t be displayed even if they have an entity status of “enabled”.
If I then take control of such a default dashboard, sure enough, any battery
sensor is missing.
Is this intentional? I can’t find anything in the docs to explain this behaviour, and I can’t think of any obvious benefit for these to be explicitly excluded.
Preempting some anticipated questions:
- Yes, I know that other sensors are also excluded from default dashboards, such as those shown under the Diagnostic header of the device page. However, if I add such sensors to a group, they are usually then displayed on a default dashboard—unless they’re a
battery
sensor. - Yes, I know that I can get them displaying on controlled dashboards. I’m keen to get them displaying on my default dashboard though, which I (try to) use as a catch-all/debugging view for most available sensors without having to modify it every time a sensor is added or removed.
