Why are people asking the same questions over and over again? (Or the Regulars' Chatroom) šŸ¤·
OK, another rant that I deleted there. Iā€™ll shorten it.
Can cable connectors be allowed to have pronouns?
What terms would they replace male and female connectors with?
Plug and receptacle?
*hides my laser screwdriver build in progressā€¦
Sonics are so passeā€™
How about bird and nest.
Far too suggestive of fornication.
Nope
(See full definition)
:zipper_mouth_face:
Rule 34 should cancel all that out.
Even if you say side A and side B the shape of the letters have connotations.
Pointy and holey sides?
In todayā€™s assortment of plugs thereā€™s no lack of diversity and equality, but what about inclusivity? I propose replacing gender-biased connotations for a more quantum mindset.
I have a Laptop with 9 holes
That doesnā€™t ā€œtriggerā€ me to propose gender bias
( Which btw reminded me that they all are ā€œPortsā€ )
Socket and plug works fine for electrical connections. Would it work for everything else?
Of course, biological sex is different to gender (identity), so male/female (vs man/woman) might still be OK. Connections typically are only binary.
Letā€™s get rid of connections and require everyone to solder their own wires! :joy:
Or give everything a screw connector block. ā€œI put the pointy wire into theā€¦ Ughā€¦ā€ :grimacing:
Adaptors however can be Female-Female or Male-Male. Or even three way Ts.
Anderson connectors are genderless.
Then there are things like reverse polarity SMA connectors.
Hmm, youā€™re rightā€¦ I just woke up. As usual, itā€™s complicated.
Please tell me that screenshot is fake.
Hose is sometimes used for ā€œsocketā€ , so there is some ā€œgender-lessā€ descriptions to choose from.
An extension-cord have a Hose and a plug, a Device/Installation have a Port/Socket
Pins are ā€œPinsā€ ā€¦ Whatā€™s the ā€œcorrectā€ female counterpart here ? :crazy_face:
Pun intended, I assumeā€¦
also pins
i was thinking on the cables, with the ā€œconnector-hoseā€ you attached to Pins, when not soldering
Iā€™ve never heard that used. Must be a local language thing.
