Why are people asking the same questions over and over again? (Or the Regulars' Chatroom) šŸ¤·
I noticed this as well and with the plethora of configurations available, Iā€™m stuck sitting reading most of them like ā€œwell, how do you have your network setup? How is your VM server setup? VLANs?ā€ But then that can spiral out of control quickly and become a ā€œhelp me un-f*ck my network please because I watched a YT videoā€ thread.
Thereā€™s just so many things that can throw simple routing out of whack.
I guess Iā€™m stuck deciding if / how I want to tackle them. I agree, I donā€™t want to be fixing their network or their VM config.
Exactly. And trying to convince someone that running 10 VLANs on a simple ASUS router with custom firmware flashed on it (true story from a few weeks ago)ā€¦ yeah, no. Iā€™m not doing that. lol
I have never been able to deal with VMā€™s, I do my network splits using subnets and network masks.
I started out using VMs with HA and avoid those questions like the plague. I donā€™t think itā€™s a bad idea for the Cookbook.
Unless the person on the other side knows or is capable to quickly learn what heā€™s doing, itā€™s generally a rabbit hole to offer detailed help on networking or virtualization troubles.
VLANā€™s are not a supported configuration.
I saw Frenck say that to someone not too long ago, so I would not try to show people how.
I could show people how I do it with subnets to separate and isolate, but unless you really understand subnet masks and CIDR Address notation, I wouldnā€™t recommend people doing it.
Itā€™s still listed as a valid install method on the main site under Expert, but I am convinced folks ignore the Expert tag :sweat_smile:
Hang on, said that wrongā€¦ I didnā€™t mean VM.
I edited it, meant VLANā€™s.
That makes more senseā€¦lol
Too many people being scared by youtube videos about being hacked by iot devices. But if you donā€™t know what you are doing, stay away from VLANā€™s.
Itā€™s ALIVEā€¦maybe
Yeah, noticed yesterday. thread will probably be filled with Ā«works in x countryĀ» pretty soon.
HA on a virtual machine is great btw, 10/10 would recommend. Ethernet Zigbee coordinator and snapshot based backups (I use Veeam) makes you quite resilient :blush:
Wait, what? This is the first time I heard about reversing fans. What difference does it make? Does it blow warm air if you reverse it? :grin:
Winter: blow hotter air from higher up to lower down in the room. Assuming there is actually warmer air up there.
Summer: cause a breeze by drawing air up - displacing the hot air up high and probably circulating it down low.
Iā€™m not a fan (pun) of this method of heating/cooling.
That actually works? I live in a country where itā€™s hot 9 months of the year.
All our fans blow air - I had never heard of a fan being reversed to suck air. TIL.
You are kidding right?
:upside_down_face:
I switch my fan direction literally daily.
I swear I had never heard of this. Might be an America-only thing, but Iā€™m not sure.
Itā€™s a huge difference! Iā€™m in the Southern US so its also hot here about 9 months out of the year.
I use it to keep a more constant room temp. I use ModernForm fans, but most US fans have a reversible switch on the fan housing.
