Hi, I’m new to Home Assistant. I included a HoneyWell T6 Pro Z-Wave Plus thermostat in my Z-Wave network. When I open the Home Assistant UI, I see four near-identical cards. Is this expected behavior?
I use the built-in HomeKit component to make Home Assistant entities available to HomeKit. In Apple’s Home app, I see five near-identical cards for this thermostat:
Details:
I run Home Assistant 0.96.4 in a Docker container on a Raspberry Pi 2B+ using the homeassistant/raspberrypi3-homeassistant
image. I use a Linear HUSBZB-1 USB Z-Wave Controller.
Possibly Related:
Home Assistant 0.96 shipped a big rewrite of the climate component: https://www.home-assistant.io/blog/#climate.
A manufacturer-specific XML file for the Honeywell T6 Pro Z-Wave Plus thermostat was merged in upstream OpenZWave, but is not included in Home Assistant’s OZW fork: https://github.com/OpenZWave/open-zwave/pull/1757/files
