Why can’t I update Home Assistant Supervised?
Hello everyone, I am trying to update the version of Home Assistant Supervised from the:
2021.12.2 to 2022.01.1
and I can’t get the container: hassio_supervisor stops.
System info:
Versión core-2021.12.10
Tipo de instalación Home Assistant Supervised
Desarrollo false
Supervisor true
Docker true
Usuario root
Entorno virtual false
Versión de Python 3.9.7
Nombre del Sistema Operativo Linux
Versión del Sistema Operativo 4.19.0-18-amd64
Arquitectura de CPU x86_64
Zona horaria Europe/Madrid
Home Assistant Community Store
GitHub API ok
Github API Calls Remaining 4964
Installed Version 1.21.0
Stage running
Available Repositories 1037
Downloaded Repositories 6
Home Assistant Cloud
Iniciada sesión false
Servidor de Certificados accesible ok
Servidor de Autenticación accesible ok
Home Assistant Cloud accesible ok
Home Assistant Supervisor
Sistema operativo del Host Debian GNU/Linux 11 (bullseye)
Canal de actualización stable
Versión del Supervisor supervisor-2021.12.2
Versión de Docker 20.10.12
Disco total 467.0 GB
Disco usado 43.0 GB
Saludable Unhealthy – más información
Soportado Unsupported – más información
API del Supervisor ok
Versión del API ok
Complementos instalados SQLite Web (3.2.1), Let’s Encrypt (4.12.0), Terminal & SSH (9.3.0), File editor (5.3.3)
Lovelace
Paneles de control 3
Recursos 1
Vistas 18
Modo storage
LOG:
when updating the supervisor log is (immediately the container: hassio_supervisor is stops):
22-02-09 16:27:50 INFO (MainThread) [__main__] Closing Supervisor
Sentry is attempting to send 1 pending error messages
Waiting up to 2 seconds
Press Ctrl-C to quit
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[15:31:45] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:31:45] INFO: Starting local supervisor watchdog...
22-02-09 15:31:46 INFO (MainThread) [__main__] Initializing Supervisor setup
22-02-09 15:31:46 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-02-09 16:31:46 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
22-02-09 16:31:46 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2021.12.2
22-02-09 16:31:46 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-02-09 16:31:46 WARNING (SyncWorker_1) [supervisor.docker.interface] Can't find homeassistant/amd64-hassio-supervisor for cleanup
22-02-09 16:31:46 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-02-09 16:31:46 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-09 16:31:46 ERROR (MainThread) [supervisor.core] Update '2022.01.1' of Supervisor '2021.12.2' failed!
22-02-09 16:31:46 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_ROLLBACK - ContextType.SUPERVISOR / None
22-02-09 16:31:46 INFO (MainThread) [__main__] Setting up Supervisor
22-02-09 16:31:46 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-02-09 16:31:46 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-02-09 16:31:46 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-02-09 16:31:46 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-02-09 16:31:46 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-02-09 16:31:46 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-02-09 16:31:47 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-02-09 16:31:47 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-02-09 16:31:47 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-02-09 16:31:47 WARNING (MainThread) [supervisor.dbus.manager] Can't load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-02-09 16:31:47 INFO (MainThread) [supervisor.host.info] Updating local host information
22-02-09 16:31:47 INFO (MainThread) [supervisor.host.services] Updating service information
22-02-09 16:31:47 INFO (MainThread) [supervisor.host.network] Updating local network information
22-02-09 16:31:48 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-02-09 16:31:48 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-02-09 16:31:48 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-02-09 16:31:48 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2021.12.0
22-02-09 16:31:48 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0
22-02-09 16:31:48 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-02-09 16:31:48 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0
22-02-09 16:31:48 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-02-09 16:31:48 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-multicast with version 2021.04.0
22-02-09 16:31:48 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-02-09 16:31:48 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2021.12.10
22-02-09 16:31:48 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
22-02-09 16:31:48 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-02-09 16:31:49 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-02-09 16:31:49 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-02-09 16:31:51 INFO (MainThread) [supervisor.store] Loading add-ons from store: 62 all - 62 new - 0 remove
22-02-09 16:31:51 INFO (MainThread) [supervisor.addons] Found 4 installed add-ons
22-02-09 16:31:51 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-letsencrypt with version 4.12.0
22-02-09 16:31:51 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-ssh with version 9.3.0
22-02-09 16:31:51 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/sqlite-web/amd64 with version 3.2.1
22-02-09 16:31:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.3.3
22-02-09 16:31:51 INFO (MainThread) [supervisor.backups.manager] Found 65 backup files
22-02-09 16:31:51 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-02-09 16:31:51 INFO (MainThread) [supervisor.ingress] Loaded 31 ingress sessions
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-09 16:31:51 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-02-09 16:31:51 INFO (MainThread) [__main__] Running Supervisor
22-02-09 16:31:51 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
22-02-09 16:31:51 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
22-02-09 16:31:51 WARNING (MainThread) [supervisor.core] Ignoring Supervisor updates!
22-02-09 16:31:51 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-02-09 16:31:51 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-02-09 16:31:51 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-02-09 16:31:51 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-02-09 16:31:51 INFO (MainThread) [supervisor.host.info] Updating local host information
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-02-09 16:31:51 INFO (MainThread) [supervisor.host.services] Updating service information
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
22-02-09 16:31:51 INFO (MainThread) [supervisor.host.network] Updating local network information
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-02-09 16:31:51 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-02-09 16:31:51 WARNING (MainThread) [supervisor.resolution.evaluations.base] Found unsupported images: {'jc21/nginx-proxy-manager', 'telegraf', 'grafana/grafana', 'ebrianne/duckdns-go', 'vladgh/minidlna', 'nodered/node-red', 'philhawthorne/ha-dockermon', 'ghcr.io/joseantmazonsb/linguard', 'portainer/portainer-ce', 'eclipse-mosquitto', 'quay.io/influxdb/influxdb', 'influxdb', 'koenkk/zigbee2mqtt', 'chronograf'} (more-info: https://www.home-assistant.io/more-info/unsupported/software)
22-02-09 16:31:52 INFO (MainThread) [supervisor.host.manager] Host information reload completed
Grades:
- Healthy Unhealthy – more information
Supported Unsupported – more information
they have always been in this state.
2.also update the version from debian 10 to debian 11
Also install agent: Agent for Home Assistant OS successfully.
3.I can’t update the: Home Assistant Core 2021.12.10 either. to 2022.2.5,
error: HomeAssistantCore.update’ blocked from execution, system is not healthy
any help will be welcome. thanks!!!
